You cannot make a 3 phase motor into a single phase motor.
You could, ( as you suggested), buy a single phase to 3 phase inverter. Even a 'variable speed drive' VF (variable frequency drive) inverter for greater flexibility, but depending on the size and purpose of your motor the cost might prove to be prohibitive.
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
It is indeed possible to use ONE Phase to run a motor, You simply use One Phase and Neutral. BUT ONLY if the 3 phase is Double, more or less, the required usage Voltage, EG: 440 3 phase, will be OK, for 220 single phase, . But 220 3 Phase,will not run a 240. single Phase. So in your case is suspect not, it really will do no harm to try though. it just wouldn't work, if not enough "juice", be careful.
http://en.wikipedia.org/wiki/Three-phase_electric_power
