Forgotten my googel account and password
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. You shouldn't need internet connectivity to unlock the phone. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the device is using or the original password used.
In some cases, if the device can receive a call, you can access the menu during the call and disable the screen lock.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account or changed password won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
An article on this topic: http://einartysen.se/unlock-android-phone-after-too-many-pattern-attempts/
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: i have a samsung galaxy
The way around this is to factory reset the phone.
1. switch off. Hold volume UP and power button and home button
simultaneously. release home button (and press again) while still
holding volume up and power button. A boot up screen will pop up. Use
volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked.
Get another phone to call your phone. as soon as you swipe answer press
back key (arrow key) (you gotta be quick) and the main home screen will
come up . press the left menu button and select settings and turn
off pattern code then go to menu and factory reset the phone again.
Hope this helps.
SOURCE: I've forgotten the pattern security password to
Going to need to hard reset the phone. YOU WILL LOOSE ALL DATA!
Power the phone off
Hold down the power button and the volume up and down button at the same time
This will take you to recovery mode.
Use the volume up/down to select wipe data and there you go!
You will loose all data on the phone.
Dan
SOURCE: i tried unlockin my galaxy
Try clicking "forgot my password" on Google from a computer. It should assist you in recovering your google password.
SOURCE: forgot user name and password to unlock samsung gt s5360
UNLOCK BY USING MY USERNAME AND PASSWORD
