I have a hand steamer and use it every time I wear a garment that's a wrinkle-magnet. Usually it does the trick but I may have to steam it for five to ten minutes. Floor steamers that are often used in department stores have a larger capacity water tank and tend to be the most effective. But they also cost a lot more than a hand-held steamer.
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
Sorry to hear that! The burnt plastic smell indicates that the element over heated to a point that the heat radiation melted the substance. The internal heating element has shorted out and took with it vital accessories necessary for normal function of the steamer. Too many parts have become inoperative and the cost of repair is excessive. The only solution is to replace the streamer. Do not plug the defective unit into a live power outlet for safety reasons.
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
