SOURCE: My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
SOURCE: Won't drain. Blinking pause. Won't
Hi.
You need to check the drain filter, which is directly connected to the pump. That is the place where you usually find blockage. The filter or coin trap is located inside the drum. See the schematic below:
If that is not enough, then the drain pump access is located in the front side of the machine, hidden behind the trim at the base. The kick panel is held to the washer's frame by screws:
After removing the panel you will Be able to access the pump. Have a container ready to collect water that will come out through the hose.
DISCONNECT POWER before starting the job.
Here parts diagrams: GLTF2940FS1 - parts catalog
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
