tengo instalada la alarma en mi coche,al apagarlo no suben los seguros de las puertastengo instalada la alarma en mi coche,al apagarlo no suben los seguros de las puertas
You can't post conmments that contain an email address.
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
It probably needs to replaced. Audio Vox has several models that have window breakage sensors. These sensors are notoriously unreliable and do this quite often. I would replace the alarm itself.
remove the fuse in the main harness going in to the alarm unit under the dash, if you have a starter kill feature you may need to bypass this. you will need to make up a jumper wire and place it in pin 30 and 87 on the relay
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
I made that but I only found the application manual , I need the installation manual.
Regards,
wilsinio
Prestige Platinum APS95BT3
