A
Anonymous Posted on Dec 05, 2013
How to delete playlist - Audio Players & Recorders
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Dec 05, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466348
Points
5959
If you delete the physical .m3u file on your computer it will not sync with itunes and then with your ipod
  • mikadot
    mikadot Dec 05, 2013
    to unhide file extensions in win7, vista go to my computer (or windows explorer) Organize/folder and search options/view change 'Do not show hidden files and folders' to 'Show hidden files and folders' uncheck 'Hide extensions for known file types' if you wish you can uncheck 'Hide protected operating system files'
  • mikadot
    win8 too :)
How can I delete songs from my iPod playlist?
If you want to manage songs on your iPod's playlist, then you can count on this iTransfer tool. It helps you manage playlists of the iOS devices/iTunes. You could add music to playlists, export/rename/delete the playlists.
Leawo iTransfer User Guide How to Manage Playlists of iPhone iTunes
How do I delete a playlist from an iPad?
If it is a playlist that you created on the iPad - not a synced playlist - just tap and hold down on the playlist icon and an X will pop up to delete it.
There are 3 ways you can resort to delete playlist from iPhone. Just follow one of them.
If you are annoyed by using iTunes to manage music in your iPod, you may not want to use it to delete playlist from iPod either. Fortunately, besides iTunes, you can use the third-party iPod transfer software to finish the task. Leawo iTransfer is regarded as the best one among all the iPod transfer programs available in the market.
Step 1. Run Leawo iTransfer and connect iPod to computer with USB cable. The software will recognize your iPod and display your iPod information on the main interface.
Step 2. Click the name of iPod in the left sidebar. Then you could see 2 categories: LIBRARY and PLAYLIST. Open "Playlists" tab. All available playlists on your iPod would show up. When you select one playlist, the songs in this playlist will show up in the right part.
Step 3. Right-click the name of the playlist you want to delete, and choose "Delete Playlist" button. Leawo iTransfer would immediately help you remove the selected playlist on your iPod device. The songs in this playlist won't be deleted, so don't worry about that.
When Leawo iTransfer finishes deleting playlist from iPod, users can enjoy the songs in iPod without switching playlists. With Leawo iTransfer, you won't lose any songs of the playlists deleted. So even if you delete all playlists from your iPod device within Leawo iTransfer, you can still enjoy the songs with iPod, or in a much easier way.
Note:
1. Leawo iTransfer supports all iPod models, including: iPod touch, iPod Shuffle, iPod Nano, iPod Mini, iPod Classic.
2. Excepting deleting playlist from iPod, it also helps with other data transfers of iOS devices, for example, you can transfer music from iPhone to computer with this software.
For more methods, check: 3 Ways to Delete Playlist from iPod
Do not privacy on my playlists. How do I get it deleted?
you can delete your playlist by going to your playlist delete option where you can delete your playlist as you want.
2helpful
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
1helpful
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
How do I erase the playlists on my sansa fuse 2gb player?
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
1helpful
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
1helpful
3answers
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
 Grubhead
Grubhead
SmartAviator
SmartAviator
