Is the hydraulic fluid level correct ??? sounds like you're running out of hydraulic fluid. because if your trying to turn as your raising the lift then i could see a problem but if it's lifted and you're having an issue then fluid comes to mind first
Testimonial: "Oil level is fine but it is definitely if there is not enough fluid for both the steering and the lift."
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
SOURCE: hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
SOURCE: All hidraulics funtions are dead, no hydraulic power in machine.
first thing I would do is test the pump itself even if no wear is found you could have a GPM loss.
So you need to do a flow test on it to find otu how much the loss is and check it to the specs of that hydrolic pump first.
SOURCE: JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
have a look at your priority valve, it is sticky. situated under the R floorboard. disassemble, clean, assemble and see the difference
