SOURCE: Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
SOURCE: Water, apparently from the freezer
This is a common issue on some fridges. It is caused by:
1. Broken drain pipe.
2. Clogged drain pipe.
most of the times, the drain pipe gets clogged. It is hard to clean and not easy to replace. It should be visible at the back of the bottom of fridge.
Removing the vegetables compartment, you should be able to find it. If you are a handyman, you may be able to replace it, but it is not an easy job. Quite dirty job I may say.
I hope this helps.
SOURCE: MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Testimonial: "Thanks for the info. with a blow dryer , and turkey baster and a hour worth of fun, we finally got it to drain."
SOURCE: Freezer Freezes, but Ice/frost collects
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: The model number on our
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28247922&pkw_=basket&model_id=5150557&NewWindow=1
Open this diagram and see #23. Remove this and at the bottom you will see a drain hole which is blocked. Using a solution of baking soda and hot water and pour it down till it runs free.
If it is frozen, defrost with a hair dryer.
