The fuel filter on this vehicle is located inside the fuel tank and is an integral part of the fuel pump module assembly. As such, it's not replaceable by itself and can only be serviced by replacing the entire pump module. It's a "lifetime" filter.
However, you might be lucky. Unlike many cars you have to drop the fuel tank. This one has a panel under the back seat you can remove. You didn't specifiy your model so this is for a Optra LS, 1.8L engine.
A PCV valve's a 1 way valve that ensures evacuation of gases from inside a gasoline internal combustion engine's crankcase.------------------------------------------------------------------------------ super mb star
It is located on the left side of the engine(frt view) remove the rad hose then the 2 bolts holding the housing to the engine and you will find the thermostat.
Huh? Looking for the TWO starters? There is only one starter for your truck. This year has two different OPTIONS for starters. Meaning, it's EITHER one or the other. The older style, a huge one, or newer smaller style. Starter IS located on passanger side under exhaust manifold next to oil pan and above tranni cooler lines if you have auto tranni.
I dont know about having it unlocked at the dealership but whenever i disconnect the battery and reconnect, i use the code 6361 and the system is up and running again. hope this helps
