Toro Lawn Mower With Toro Power Tools Logo
Posted on May 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Toro Wheel Horse Lawn Tractor will not start. Engine makes a loud clicking noise when the key is truned.
Bob B
Level 3:
President:
  • Master 272 Answers
  • Posted on May 10, 2009
 Bob B
Master
Level 3:
President:
Answers
272
Questions
0
Helped
224535
Points
1890
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
I have Toro Wheel Horse model # 71225 and does not turn over. Charger indicates full charge
pull the plug out and see if it will turn over it could have overheated causing it to lock up if it is look at buying short block are new motor but befor doing this how old is it is it worth buying a new motor
Aug 12, 2014 • Toro Garden
Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Nov 12, 2013 • Toro Garden
Toro wheel horse 13-38xl lawn mower won,t start, makes buzzing sound when key is turned on,checked solenoid with screw driver but will not start motor, tuned pulley under motor and wheel on top of motor...
If you crossed the two battery terminals on the solenoid and the engine did not turn over, I would check the battery terminals first to see if they are tight. Then check the terminals at the solenoid to see if they are tight. If all of this is tight and you are sure you have 12 volts at the solenoid, then your starter is bad.
Aug 23, 2013 • Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 • Toro Garden
When starting my mower the starter makes clunking noise
Something broken in starter. Remove and check or have shop check it.
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to...
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
1helpful
I am looking for a manual for a Wheel Horse lawn tractor, Model HH100-115145C
The model numbers you show are to a Tecumseh engine. If this is what you are searching for, you can go to www.outdoorpowerdistributors.com.
There you can get a pictorial with part numbers.
1helpful
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
1helpful
I have a 20073A self propelled lawn mower that makes a grinding sound when I start out mowing or turn the mower around. I replaced the metal gears twice and that quiets it for awhile, but then the noise...
Assuming the pinion gears and wheel gears match, (sometimes dealers make mistakes too.) Check the bearings behind the wheel adjusters and the retainer-bushing Hoc. If they are in good shape lubricate the pinion gears and wheel gears w/ hi temp lithium grease.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
