Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Go to Start> Run > type " msconfig"> "ststem configaration utility" window will apear, select the tab "StartUp"., select "Disable All" and apply and OK. it will ask to restart wait till it restarts. if it is not restarting. do the same thing in "Safe Mode". if you dont know hot to go to safe mode. Just press "F8" key when booting. the menu will apear, select "Safe mode" do above method in safemode and restart. this method will work in most of cases. best of luck.
Hi there please configar the printer & pc connectivity via Bluetooth first then go for test print. If not working then uninstall the printer driver and restart the pc and again install it. During installation open your eyes and read properly all the instruction. Let me know whats going on.
u have to chek internet connection and rounter settung set yr rounter to DHCP mode and configar yr internet in to router after configar yr laptop need to find yr rounter for that u need to run surch wizard it's automatioc found yr rounter then just pair it it's help u..:)
Dear Shaya,
This problem related with configaration cnectionctions in your phone, so please let me know which network SIM yor using for further solutions, it is simple problem onece you know configaration.
