My icemaker stopped filling with water. If I hold the icemaker test button the tray will rotate about 15 degrees in one direction, then the other, but that is it. I don't know if it is supposed to rotate more than that but with no water it doesn't really matter. I tried removing and resetting the water filter as well as unplugging the fridge for 15 seconds or so.
SOURCE: Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
SOURCE: Samsung RS195BSBB Ice Maker not working properly.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
