SOURCE: I have an All Pro
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If
the units starts up and runs good and slowly goes out it will normally
be due to a lack of fuel getting to the nozzle. When there is not enough
fuel being delivered to the nozzle from either a clogged fuel filter of
dirty air pump output filter the unit will slowly shut down from lack
of fuel.
If the unit shuts down while it is running properly and
the nose come is orange then you probably have a problem with a
photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
SOURCE: Torpedo heater runs for a minute or two then the breaker trips.
You can test the photocell by hooking up a ohm meter on thr rx1k scale. Photo cell should be out of the heater.Hold photocell up to a light bulb,with light on resistance of photocell should drop to 0 to 100 ohms.Holding finger over the photcell and blocking the light the resistance should go up to the maximum resistance
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
heater...
Reddy
Torpedo
heatman101
heater...
Reddy
Torpedo
heatman101
heater...
Reddy
Torpedo
heatman101
Here
is a tip about troubleshooting Torpedo Heaters
Reddy
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
heatman101
heatman101
