Tablets & eReaders Logo
r
robert Posted on Dec 01, 2013
Reset vivitar xo tablet
Wont boot
Max Edmiston
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 25, 2014
Max Edmiston
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
10532
Points
The reset worked for me, but I had to do in following order:
1. Turn off device
2. Hold down volume -
3. Hold down power at same time as volume -
4. Hold down volume + at same time as power and volume -
Doing this brought me to the Android screen where I chose to reset to factory defaults and also to clear cache, then chose to reboot.
- Max
  • 1 more comment
  • Ginger Randall
    Ginger Randall Nov 05, 2015
    Worked like a charm! Thank you :-)
  • Mansi
    Mansi Feb 05, 2018
    I have a xo 780 tablet
    How to download firmware?
    Plz! Link ....
  • jelabarre Nov 23, 2018
    nope, doesn't work. Tablet just sits at the X logo, never goes any further. Tried combinations of vol-, vol+, oth with power button, extended presses of the reset button, tablet will not clear.
    So much for being an "open specification" device, when useful data about the hardware in non-available.
1 Related Answer
tarek-pc
  • 7 Answers
  • Posted on Dec 07, 2013
SOURCE: Tablet wont boot
turn it off then hold volume up and power until get recovery mode then using volume key to select wipe factory then click power then after finish select wipe cache then reboot 12_7_2013_12_41_10_am.jpg
My camelio by vivitar is stuck on opening screen. How can I fix this?
If your Vivitar Camelio tablet is stuck on the opening screen, you can try the following steps to fix it:
  1. Perform a soft reset by pressing and holding the power button for 10-15 seconds until the screen turns off. Then, release the power button and press it again to turn on the tablet.
  2. If the soft reset doesn't work, try a hard reset by pressing and holding the volume up button and the power button at the same time for 10-15 seconds until the tablet vibrates and the Vivitar logo appears. Release the buttons and wait for the tablet to reboot.
  3. If the above steps don't work, try connecting the tablet to a computer with a USB cable and see if it recognizes the device. If it does, you may be able to restore the tablet to its factory settings using software provided by Vivitar.
  4. If none of the above steps work, you may need to contact Vivitar customer support for further assistance or bring the tablet to a repair shop.
My tablet wont charge.when i plug it in the orange light will come on but it wont charge.
This is a fatal problem. Your device needs to be replaced. ;( call up customer service. Then, when your tablet gets repaired/replaced, Get a strong case and NEVER LET THAT 2 YEAR OLD TOUCH THAT TABLET AGAIN! Hope I helped!
~Conner
Tablet locked and don't remember password
Do a hard reset. You will lose all stored data. No other way. Check the manual for the steps to hard reset
How can the apps that are not desired removed/deleted?
Android hold finger on app for a few seconds then it will have an x
in the upper right corner. Tap the x to delete.
1helpful
How to reset a vivitar tablet
I'm afraid you're right, reset is the way to go. Hold down the volume-up button and press the power button, then choose the reset instructions onscreen (should be a small menu in orange).
1helpful
Forgotten parental password
Here's how to reset the tablet:
www.xotablet.com/pdf/xotablet-quick-start.pdf
4helpful
Setup xo tablet but I dont remember doing a parent password n now its asking for one an I don't no it. Trying to get password to set wifi
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
