Microwave beeps and reads KEYPAD SHORTED --SERVICE MAY BE NEEDED. The only way I have found to stop the beeping is by unplugging it. I have tried holding the Clear/off button; it changes nothing. I would like to know if their is a possible fix (that won't cost as much as a new unit) or if the unit needs replacing? THanks
SOURCE: microwave beeping and says keypad short may need
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
he most likely cause of this problem is a keypad on the control.
You can try the stop/clear keypad to silence the beeping.
You can put the controls into child lock and see if the intermittent beeping stops. The instructions to turn the child lock feature you have it in the owner manual . The child lock disables most keypads.
otherwise replace the control board.
God bless you
