LG WD-3243RHD Front Load Washer / Dryer Logo
R. G. Posted on May 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothes take forever to dry. noticeably longer than before.
Combo unit, about a year ago, wasn't draining so pump was replaced by service technician. Clothes took forever to dry to begin with, but now it seems to take double the time. There's no lint catch so I'm wondering if that's a problem. the pump filter was virtually empty. Lint builds up around drum gasket, hard to get to and there's a little pool of standing water in the gasket where the front loader door closes. Any ideas on this?
  • 7 more comments
  • R. G. May 10, 2009
    I'll check on this tomorrow.
    Ran a small load. After the spin cycle, the clothes were damp, not soaked. So it seemed pretty normal.
  • R. G. May 11, 2009
    Ok, i ran the dryer. About halfway through, the clothes were definitely warm/hot and damp. there is heat being given off. Not soaked.
    Well, it happened before, and i cleaned out the lint around the drum by the gasket and it seemed to help. Over the last week, it seems to be taking a lot longer to dry the same loads that we've always done. Low heat is possible, i supposed. I just checked it again in the middle, clothes are a dryer damp, and the dryer is really warm. But, i can touch the metal drum without it burning my hand. Would you say that's low heat?
    update: I live in a condo so it's not vented. I just let the last load last forever on sensor and the laundry came out pretty wet (had to wring out some water). But still no standing water in the bottom like the problem before, so I don't think it's the pump. any ideas?Should i have a technician check it out?
  • Anonymous May 11, 2010
    Difficult to say for sure, but the heat level kinda sounds normal.
    Just a thought, have the dryer vent hose and the outside exhaust flap been cleaned lately? I assume there is a hose -- with no lint filter, there must be a lot of lint going somewhere.
    Okay. Would you say then, if it is taking too long to dry clothes, that the dryer might be running on low heat and not high heat? I know this is subjective, but consider I am doing this hundreds of miles from the suspect dryer.
    About halfway thru the drying cycle, open the lid to see how warm it is in the drum -- let me know what you find -- at this point how damp are the clothes?
    Have you checked the clothes after spin to see how wet they are?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
563
Points
Question, I just moved in to a condo with this machine. When you say clothes took forever to dry to begin with, how long was forever?
Did you always have to run a separate dry cycle after the combo cycle (which is already alot longer than most machines).?
How big/small of a load can this machine normally take? I put in 1 bedsheet set with 3 cotton t-shirts and it wouldn't dry it. That's a really small load, that didn't even half fill this tiny machine and it still didn't dry!
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on May 11, 2009
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
765887
Points
4966
Yes, sounds like a service tech is a good idea.
Charlie
3answers
My heating element won't stay on very long and it takes forever to dry
you shud be able to purchase a replacement here>>www.discountbargainprices.com
Dec 26, 2018 • Dryers
2answers
How come my washing machine cannot spin dry my clothes even I put the function for spin dry
not spinning fast enough
call an technician to check program board or for other faults
4helpful
Spin cycle is not getting clothes completely dry, can still hand ring water from clothing
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
1helpful
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
HELP
HELP
HELP
2answers
2helpful
Clothes seem too wet after final spin
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Wife just told me this
try a new drain pump make sure there is no foriegn objects in there
1helpful
3answers
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
