Before I got my my Proscan tv, I plugged in my Netgear Neo TV device into the tv and Netflix,vudu Hulu, etc... would all pop up and I could watch. When I got the proscan and Dish Network, I plugged the device into the port in the back of tv and nothing. Before I could go to like channel 99, then Video 1 Video 2 Video 3, then HDMI1, HDMI2 and HDMI 3. The tv doesn't go to any of these channels it goes like channel 9980 then to dhannel 02. I have a Netflix button on my NetGear Neo TV remote, I have even hit that and it doesn't come up on the tv. What's the best way to watch Netflix on a proscan tv and what device is the best ( my netger neo TV player or a blue ray dvd player or what?)
It could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
SOURCE: "No Signal" Message when using HDMI Inputs on 26" Proscan LCD TV
You MUST get HDMI Driver for your Video Card, it is NOT standard. You need to go to PC makers web site and download latest Video Divers for your PC, then you must set up Multiple Desktops, To do that you must first connect the TV, but leave OFF, connect up to PC, reboot, setup Video Card, turn ON TV, TV will have already been detected, On PC, Share the desktop, or Clone, whatever you wish, now reboot after saving settings. Now you set the TV for HDMI already and it should show you a desktop when chosen. You must select and setup TV, FIRST, then connect the PC. From then on, Turn the TV ON, then turn the PC ON, that way it will Always detect the HDMI port.
