Question about Toshiba Satellite A205-S4617 Notebook
My Satellite A100 laptop has no numerric key pad so how can I type special characters?
    Scholar:
  • 56 Answers
You should have numbers on the keyboard which you can access using the Fn button... you can also use these without the FN button by htting the NumLock button, then use as normal keypad....
other that that try using the Alt button and the Fn with the corresponding digits.So hold down Alt, FN and tap the corresponding digits/letters on the keyboard.
If you need to use a numpad a lot, then can purchase a USB numpad - often included with USB kits from gadget shops.
Posted on Nov 29, 2013
Testimonial: "My keyboard does not have a numlock button; it is an A100 Satellite laptop"
  • 1 more comment
  • Paul de Braux
    Paul de Braux Nov 30, 2013
  • Thomas Lynch Nov 30, 2013
    in this case the following should help you. You may have to relearn some codes but if you use the same ones regularly then it may not be a problem for you. Depending on the application you use - MS Word for example you can use the Alt + X shortcut. Enter the hex code of the special character you want then press Alt + X together and watch the number magically change to your desired code...
    for example to enter the @ symbol ( i know you have this on your keyboard already... ) but you type 64 and press Alt + X and it will change to @ - for the copyright symbol type A9 and then press Alt + X and is should appear.. not all applications will support this - but hopefully yours will.
Anonymous
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Toshiba Satellite A105 number pad doesn't work
u may want to check wether the num lock key is on or off its on u cna type nos
Posted on Feb 24, 2009
marketex
Maurice B Thomas
  • 371 Answers
SOURCE: Toshiba Satellite A45-S250 non-numeric keys locked
Your keyboard logic chip is in need of therapy.
Replacement of keyboard warranted.
Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
Posted on Mar 30, 2009
Anonymous
  • 36 Answers
SOURCE: cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
Posted on Aug 11, 2009
Anonymous
  • 102 Answers
SOURCE: download and install driver(toshiba satelliet laptop a100-766
You can download the audio and network driver from this Link................
http://driverscollection.com/?H=Satellite%20A100&By=Toshiba
Thanks
Posted on Aug 15, 2009
ikkenom
  • 10406 Answers
SOURCE: 1qaz keys on my toshiba satellite a100 laptop are
A keyboard sends "scan-codes" to the computer,
e.g., "user pressed ALT and has not yet released it,
user now pressed CTRL and has not yet release it,
user now pressed DEL and released it".
So, if you've changed keyboards, then the new keyboard _should_ be sending the correct scan-codes; it must be your computer's motherboard that is not properly interpreting the scan-codes. Ouch!
Replacing the motherboard is _not_ cheap.
Posted on Apr 10, 2010
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
How do you rotate the backslash key on toshiba L300 I am always getting this symbol é
You can do this....
-Start menu
-System tools
-Character Map
And you'll get everything
Vote please ;)
Apr 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
How to unlock a laptops mouse
i'm going to assume you are tryign to unlock the mouse pad to use it again.
on the keyboard there is an Fn key. This is called Function. then there are either gray or blue alternate pictures and words on some of your keys. along the top on the F keys you can fidn one that looks liek a picture of the mouse pad. this is usally F3 on those.
hold down the Fn key and hit the F key that has the correct picture. this will reenable the mouse pad
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Originally when I pressed anything on the number pad every touch would type a 1 no matter what key I touched. The numlock light will not switch off. When I hit fn + num lock it shuts the computer down....
if you ahve any external usb keyboard just connect it to testing may be your laptop keys are stucked .try to clean the with dryer. just give hot air to keys with the help of dryer. but make sue it should not too close to keys.
Nov 20, 2009 | Toshiba Satellite A100-S8111TD Notebook
Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
When typing on toshiba the curser skip and actually moves
It might be that your palm is brushing across the intel touch pad (mouse pad) as you're typing?.. try holding down the function key (Fn) (on the lower left corner of the keyboard) while pressing F9 (this activates the "Toshiba Flash Cards Menu" and is a keyboard shortcut to toggle off/on the touch/mouse pad. You can turn it back on this way too. I almost always use a conventional USB mouse with my laptop for this reason and because it's faster than fiddling around with the pad, IMHO).
Dec 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
My question mark is an E
get a list of ascii characters and their respective 3 digit values. then you can press and hold the alt key while entering the 3 digit value on the keypad.
Sep 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Fn Mode Stuck???
uhmm sir my diagnosis is your keyboard has a problem.you need to replace it to a new one.try to return it to your store where you bought it.it has service/parts warranty.
Nov 27, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A205-S4617 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
