Hammering Logo
A
Anonymous Posted on Nov 28, 2013
Bosch jackhammer i'd plug my bosch jack hammer in but it doesn't turn on
Pieter Vleeshouwers
Level 3:
  • Master 2,029 Answers
  • Posted on Mar 26, 2016
Pieter Vleeshouwers
Master
Level 3:
Answers
2029
Questions
0
Helped
4112551
Points
7389
Broken power cable or autostop inside the carbon brush they are short its time for a revision !!
Why my Bosch brute jackhammer only hums when I press trigger? Can someone help me please?
seems as if the jackhammer motor is locked up and frozen might wanna be careful opening it up and freeing that motor up while its unplugged
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 • Drills
How do i get my jack hammer to work again
measure powercable control carbon brushes that autostop in front of the carbonbrush was coming out of the brush if thats not control the electric field to brushholders and switch.
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 • Hammering
Bosch jackhammer
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
4helpful
How to fix jackhammer it doesnt hammer.
Bosch hammer drill 11304 uses sds bits and is generally a good hammer. Usually only needs yearly (depending on use) lube with Bosch grease to keep it working well. No hammering usually means lack of lubrication or broken connecting rod on the hammer piston. Not easy to repair. Tackle only if you have lots of experience with Bosch or other complicated hammers. Parts are easy to find. Good luck.
Mar 02, 2012 • Hammering
12helpful
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Top Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hammering Expert? Answer questions, earn points and help others
