Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Amana sqd25vl freeze food in refrigerator - Amana ARB1917CSR Bottom Freezer Refrigerator
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana TempAssure
heres a link to your owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/12642722.PDF
Posted on Apr 19, 2008
mikedurland
Mike Durland
  • 481 Answers
a lower number = higher temperature
confusing isn't it! :)
let me know if you need more help
mike
Posted on Jul 02, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
Anonymous
  • 19 Answers
SOURCE: Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Posted on Mar 01, 2009
Anonymous
  • 531 Answers
SOURCE: Amana BRF20 - freezing in fresh food drawers
check your door not closing stay (ajar)
Posted on Apr 01, 2009
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 07, 2011 | Amana SXD524VW Side by Side Refrigerator
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Why is food freezing in the top comparment
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 03, 2011 | Amana AFI2538A Bottom Freezer French Door...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana SQD25VL coils cool, but deepfreeze fan does not engage
Sounds like a bad fan motor. Be sure power is getting to it.
Dec 01, 2009 | Amana Freezers
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana bottom freezer - food is freezing in refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jan 02, 2009 | Amana ABB1921DE Bottom Freezer...
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
