U-Line 15R Compact Refrigerator Logo
A
Anonymous Posted on Nov 23, 2013
Not working, the compressor is not on and there temperature is not cold
Vevor slush machine not freezing either side. Code SLS LL. Gets cold but no slush. Specific gravity of mix is at the right level. First time we have used the machine.
There are a few things that could be causing this issue. The first thing to check is the temperature of the machine. If the temperature is not cold enough, the mix will not freeze. If the temperature is correct, then the next step is to check the compressor. If the compressor is not working properly, it will not be able to freeze the mix. If the compressor is working correctly, then the next step is to check the mix itself. If the mix is not the correct consistency
Ge profile after thawed out 8ce from freezer ot will still not cool back down
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
My Amana 19cu ft refrigerator, freezer on the bottom. Refrigerator stopped working, freezer is still working, MODEL DRB1901CW. S/N109533070CE
There are plenty of reasons this could happen like the following: PROBLEM POSSIBLE CAUSE Loud operating sound level • See "Sound Information" section for explanation of normal operating sounds Freezer too warm. Compressor not operating • Freezer temperature set too warm • Defective compressor • Defective overload or relay Refrigerator too cold • Refrigerator temperature set too cold • Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section • Freezer temperature set too cold • Restricted condenser air • Refrigerant shortage or restriction • Refrigerant overcharge Freezer too warm. Compressor cuts off on overload • Heavy usage • High ambient • Restricted condenser air • Defective condenser fan motor • Loose or missing condenser fan blade • Improper voltage • Defective relay or overload • Compressor motor winding • Non-condensibles in system • Refrigerant overcharge Freezer too warm. Compressor operating • Freezer temperature set too warm • Restricted condenser air • Defective condenser fan motor • Opened door • Heavy usage • Defective freezer fan motor • Opened defrost thermostat • Opened defrost heater • Loose or missing freezer or condenser fan blade • Heavily frosted evaporator • Refrigerant shortage or restriction • Inefficient compressor Refrigerator too warm • Refrigerator temperature set too warm • Freezer temperature set too warm • Return air or air supply duct blocked • Chefs Pantry control set too warm or air supply tube blocked • Heavy usage • High ambient Problem Possible Cause Freezer too cold • Freezer temperature set too cold Long off cyde • Low ambient • Freezer temperature set too warm Short off cycle • Heavy usage • High ambient • Freezer temperature set too cold • Light constantly on • Poor door gasket seal Long or continuous run cyde • Heavy usage • High ambient • Inadequate condenser air flow • Freezer temperature set too cold • Loss or restricted refrigerant Short run cycle • Light usage • Low ambient • Freezer temperature set too warm Exterior cabinet condensation • High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions. • Freezer temperature set too cold • Poor door gasket seal • Insulation void
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Fan Motor
Start Relay
Start Capacitor
Thermistor
Compressor
Main Control Board
1helpful
The freezer doesn't freeze that good but the refridgerator does work.
It is possible that the defrost cycle is not working. Look for signs of ice built up in the freezer compartment. The excess ice prohibits the air circulation.
26128165-5xkmzur1kbcrfneaoxy43scu-3-0.jpg If defrost cycle appears working and compressor runs continuously it is probable that the Freon is low or compressor is failing.
the usual tell is the refrigerator gets colder than usual and the freezer does not get as cold. The situation is that the compressor runs until the freezer temperature is satisfied. If the compressor can not achieve the cold temperature of the freezer it will run continuously.
When the unit runs continuously the bi-pass of air is increased bringing more cold air into the refrigerator portion of the unit.
1helpful
2answers
If my freezon would be low then why is it very cold air when I'm going on the road
because the temp difference between the hi and low side will be greater faster than a normally charged system the reason it cycles off is the keep the evap. from freezing up, but running to low on Freon can cause poor lubrication in the compressor causing damage to the compressor, yes it will blow very cold for a short period of time with a low charge
My refrigerator is located in a fold garage ... A whitish liquid is leaking from the bottom of it ... Any idea what could be wrong
What you're seeing may be the oil in the system if the refrigerant system has failed leaked out - which I suspect it has.
Refrigerators do not work well in cold areas, as when the fridge's interior is cold and the compressor shuts off, the ambient temperature causes the refrigerant gas to turn to a liquid and return to the compressor. When the temperature inside the fridge rises enough to turn the compressor on - it fails catastrophically as a compressor can only compress a gas, not a liquid.
2answers
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
2helpful
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
My refrigerator in the garage shuts off when it is very cold outside. What can I do to prevent that?
Refrigerators are designed to work inside, at room temperatures.
The temperature of the freon is getting so low (and the pressures so low) that the freon is not turning into a gas before getting back to the compressor. Therefore you have liquid freon in the compressor (a very bad situation). When the liquid gets sucked into the compressor's compression chamber, you can damage the compressor; even kill it eventually.
I'm not aware of any way to solve your problem except heat your garage or move the refrigerator indoors. I definitely wouldn't run it at cold ambient temperatures!
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
