Hi, I have a Craftsman 20hp Kohler engine, 48" deck. The tractor starts and runs fine until it heats up. Once it runs for a while it starts to miss. Problem gets worse when the mowing deck is not engaged. Then mower shuts off when I lower the idle speed. I have changed the spark plugs, but the proble continues. Any suggestions? Thanks.
mower deck keeps shutting off and engine wants to cut out started last year and now mower deck wont stay on for more then 25 feet!? mower deck keeps shutting off and engine wants to cut out started last year and now mower deck wont stay on for more then 25 feet!?
You can't post conmments that contain an email address.
The serial number should give you that information. It is located on the frame under the seat or on the underside of the seat itself. If it is the Kohler engine there will also be a serial number sticker on the upper right side of the engine. These numbers should help identify the model you have. These can also help when you need to order parts.
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
