What doe the Green and red blinking light mean?
Free online manual, but unknown why the lights are blinking. A blinking light when warming up is indicated in the manual, but doesn't specify the color of the light.
https://www.projectorcentral.com/pdf/projector_manual_7109.pdf
SOURCE: Blinking red lamp light
blinking red light normally only occurs when lamp needs replacing. one thing to try other than replacing the lamp is resetting the lamp used hours timer (page 33), and if this solves the flashing light you may get some more hours out of your bulb http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/projectors/MT500.pdf The wheel noise is supposed to be normal and an element of the design - don't think they thought that one through too well. Saying that, if it is all the time and painfully loud then something (possibly the bearing or the housing that the bearing sits in) needs bending back or replacing - toshiba do not suggest any long term solution to the problem at all. Hope this helps please bother toshiba about this, and it may help stop them selling unfinished designs. We must all fight for a better future etc. etc. etc. ;) Hope this helps :)
SOURCE: Norelco Advantage red light meaning and source of manual
The manual has very little on the meaning of the light.
From the section on charging:
"1. First time charging requires a full 8 hours. Green Charge Indicator Light may begin to blink befire 8 hours has elapsed, however, continue charging razor for the full 8 hours. After the initial charge, the razor should be kept in the charging base and will recharge automatically.
Recharge at temperatures between 40 and 95 F. Charging at lower or higher temperatures adversely affects the life of the batteries.
A full charged razor will give approximately 36 minutes of shaving time.
2. Press ON/OFF button OFF. Place razor in Charging Base and plug Base into outlet. The ON/OFF button will light.
3. When the razor is fully charged, the light will blink green.
4. Return razor to Charging Base after shaving.
5. When the light starts blinking red, you need to recharge your razor. You will be able to complete the shave."
The only other mentions about charging are:
"IMPORTANT: To insure optimum battery performance, razor should be run until battery completely discharges twice a year."
"Always place razor in base first, then plug base into outlet. To disconnect, turn razor off then remove plug from base from outlet."
SOURCE: Status Light is red and blinking - Laser Printer
it means that one of the componets in the printer need replacing it could be the waste toner container. have a look at the on screen display that you get when the printer is operating
to access in windows XP go to the clock corner of your screen
you will see icons
find the one that is for the clp300 click on it and the on screen display will appear
look at the informaton and it should tell you whatt is wrong
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
