SOURCE: Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
SOURCE: cant remove shock absorber "bolt/pin" frigidaire frontload washer
one end of thosepins has a tab on it, mash the tab with pliers while pullingon theother haundi24
Testimonial: "You knew exactly what i was talking about even though my question was a bit vague and confusing. I appreciate it a lot"
SOURCE: when spinning the drum seems like it hits side
You need to take the shock off one of the pins and check to see if it is hard to move it in and out... if it moves easily then it is bad. Also check to make sure that none of the loops that the pin goes through are broken.
My bet is that the spring is broken inside of the shock where you cannot see it. you will need to actually move it in ans out to check it.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
SOURCE: I have an He3t/110 42922200.
Check upper springs first as one snaps on this model next make sure machine is level,if all else fails you could replace suspension legs/ struts....
