Video Game Consoles & Games Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disc stuck and then Ps3 system when turned on goes from green to yellow then blinking red
I pressed the eject button on my PS3 and it didn't come out and now when I turn it on it starts up for about 1 second then turns from green to yellow then blinking red.
Anonymous
Level 2:
Sniper:
  • Expert 85 Answers
  • Posted on May 18, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
85
Questions
0
Helped
42859
Points
270
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
My ps3 is flashing green yellow then red
Yellow Light Of Death, quite similar to 360's Red Ring of Death.your PS3 is part of 0.2% that has overheated and now no longer functions! Send it to Sony, they'll replace it.If you can try to
update your PS3 (in the settings menu the 1st option)
go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies
check the disc if it has fingerprints or scratches if it does then thats your problem
if you have the 60GB sos mate they have alot of problems
or maybe try this put the PS3 on then press the eject button (with no disc in) then hold it then switch the PS3 off at the back with your finger on the eject button still holding it then put it back on then the fan test should be working this may cool it down
if this problem still continues go out and buy a inter cooler from a shop
40g ps3 suddenly stopped mid game, won't eject disc, red light ON, turns green and blue for a moment (when pressed), then yellow light where green is, hums a little bit like the motor wanted to eject but...
I think that u just didn't dust it off enough and the fans could no circulate the hot air well enough and the system ended up damaging its self.
You can go to www.us.playstation.com Click on PlayStation 3<support<Service. The service link can be found in the bottom right hand corner. Just fill out a service report form and then they will ship you a box for you to re-ship your system into for repairs.
Note: If your PS3 is out of warranty you will have to pay $149 for this service with a credit card.
2helpful
I have playstation 3 model # CECHH01, a game is inside, when i power on the light goes green, then quickly goes blue then yellow and goes back to red and powers off leaving the red light blinking. What do...
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
2answers
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
1helpful
2answers
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Turn power on and the light goes from green to blinking red.
you have the yellow light of death.. go to youtube and search for that and there are some self help videos.. basically u have to take the whole machine apart and reheat the cpu and gpu chips
3helpful
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
