How do I replace a broken latch?
Does it never latch and run, or does it occasionally work? Have you tried pushing on the door? Does the latch make any sort of noise? Have you recently had the boot replaced because of mold? Sorry for all the questions in reply to your question, but if the latch is physically broken then it needs to be replaced. If the question is "how do I replace a broken Bosch latch?", that's a different question.
if you push on the door, the latch will lock, but once you remove pressure it will unlock. Without pushing, the cyllanoid will make a humming sound as if it is engaging, but it does not. Registers E01 and water pump starts going. Have to turn it to off to stop the water pump
