Acer will send you out replacement disk at no charge! www.acer.com click support and ask them for the disk, other then that you have to buy a new operating system.
The system cannot detect the hard disk drive. Before you start up, re insert the hard disk. Remove the memory card and clean it with soft cloth or tissue paper. After doing these..Start up your computer and see the results. If nothing happens, restart your laptop, hit F12 key & set the hard disk drive to first boot device then press the Enter key. wait till the OS comes up.
You probably can install Windows 7. You will have to go to Acer's site to get any special drivers, But to start, just insert the system disk and do a fresh install.
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
I'd suggest there is a possible hardware error. You need to get into the bios and check the temperatures they'll be under 'system health' or similar. Also might be worth running a ram check. Download 'windiag' it's a microsoft program designed to check your ram and it is very good.
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
