Goodman CLQ36AR49 Air Conditioner Logo
A
Anonymous Posted on Nov 17, 2013
Gsh130301ab tonnage - Goodman CLQ36AR49 Air Conditioner
william simpson
Level 3:
Genius:
  • Goodman Master 1,363 Answers
  • Posted on Aug 14, 2015
william simpson
Goodman Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
317836
Points
1636
What tonnage is ruud UBEA-21J14SFEAI
That model number is for an air handler (indoor unit) and not associated with tonnage. Air handlers are more often rated according to CFM and auxiliary heat.
In order to get the tonnage you would need to look at the model number of the outdoor unit (likely a heat pump). Typically tonnage is expressed in 1000s of BTU/hr, i.e. 24 = 2.0, 30 = 2.5, 36 = 3.0, etc.
WHAT IS TONNAGE OF BTB730A100A1
12,000 btu/ton. So figure 30÷12 its a 2.5 ton/30,000btu, IF the 30 is the tonnage. Not likely the 100 in the model# is your tonnage unless the a/c is the size of a small house.
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
1helpful
2answers
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Based on my serial no and model can you tell me
The unit is a 2 1/2 ton unit. Look at the model number and note the 030 in the sequence of numbers. That tells you the size.
1helpful
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
