Hotpoint Model TX18HHC
When the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
