We have a 7-8 year-old C-Pentane Fridge that has worked well until just the past month. Now, the fridge portion has stopped getting cold. The freezer still freezes fine. What we've noticed is that ice forms in the airshaft between the freezer and fridge causing this problem. We have opened it up 3 times to melt the ice and then it cools for a couple of days. But, then it just freezes up again. Any advice?
SOURCE: freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
SOURCE: whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
SOURCE: 3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
SOURCE: The freezer is too cold and the fridge is not cold enough.
check your door gasket it is letting is moisture.
