Car has an automatic trans. When it fails to start, there is no cranking or noise. My son said there was a blind spot in the starter, and when he struck the starter with a tire iron, the car started.
SOURCE: Hyundai Accent 1996/7 1500
I waited for about 30-60 minutes and cranked the car again and it started....first time. Why? Still don't know!!
SOURCE: 2001 Hyundai Accent cranks, won't start
its the camshaft position sensor . Its located (atleast on my 1.6L) to the right of the front HOT plate the conection runs between the engine and the right side fan. easier to work on if you take off the air intake thats by the left front side of the battery. you will be working between the fan and the motor. only one bolt but is tricky so u need a 1/4 inch nuckle with a 1/4 extention. once located and you have the right tools it will only take 30 minutes to replace....dont forget to take off negative battery cable before you start.
SOURCE: 2002 Hyundai Accent GL will turn over, but it won't start
i dont really have a solution but i have a 2002 Hyundai accent gs that wont start when it gets cold if its below 50 degrees out the car will crank but not start we have replaced everything the alternator,starter,battery,both coil pack,transmission,crank censor,oxygen censor,fuel pump relay, computer, and 100 amp alternator relay none of these things has fixed the car does any one know what else it could be
