The machine was complaining about the image unite ,then after changing it ,the machine start to show , please install the image unit correctly and close all doors on the printers screen so what do i do ?
Sometimes just open the doors and closing them a few times will work its sensing somethings open ,Make sure all is closed you may have too reinstall drivers. start over read all directions sometimes we get burnt out on trying to get something going give it a break for a bit then try again. could be a firewall or anti virus cause problems to.
SOURCE: installed the black imaging unit in konica bizhub
possible a bad image unit. you can try swapping the connector on the bottom of unit to see if it works.
SOURCE: my bizhubb c250 is displaying
open front door then push the IU correctly then close the door and close the side door from your right side...
SOURCE: install imaging drum Bizhub c352
The best way to solve your problem is to download the official Konica troubleshooting solution manual. It will tell you how to pinpoint and fix every problem reported to Konica. CLICK HERE
