Ice tray is full of ice, the next batch of ice ready to drop, but gets stuck and frozen and will no longer drop the ice. As long as you keep emptying the tray the ice will keep dropping, but once the tray is full you can no longer get the ice to drop and it freezes in place
That sounds to me like it is working exactly as it is supposed to. Once the tray is full, the arm lifts and it stops making ice. Once you use some of the ice, it will drop the arm and turn the ice maker back on.
On the back section inside the cardboard cover there is a dual solenoid operated valve that when energized by buttons on the front of the refrigerator either dispense water, (which appears to work by your descrition) and the other opens to fill ice maker tray. It sounds like the ice tray side is not enerzing or does not work. If you take your model number and go to Searspartsdirect.com you can order the replacement valve and get the system back in operation.
Before I trash a potentially good working dual valve, make sure someone has not turned the on/off switch on the ice maker and/or the bin full bail (if it has one) is in down position. The bin full bail looks shiny metallic and rotates down to the automatic position. When a batch of ice harvests, they puch up against this bail and will halt production when the bin gets full. Once lowered because of ice usages, the bail lowers again to start another batch of ice.
Hope this helps
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Yes there is a heater that releases the ice cubes from the tray as they are being elected. There is an overheat thermostate relay inseries with the element in the ice maker assembly. The element is installed in the metal housing that holds the tray.
If the cubes do not release the heater should remain on until they do. Suggest that you turn off the ice maker by lifting arm to off and wait several hours. Open door drop arm and observe. If the cubes remain stuck when ejector fingers attempt to eject and ice doesen't eject then heater is not coming on. Suggest replace ice maker. The parts are easily available and easy to replace!
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
