243 volt current at outlet. No power at the board. Already replaced heating element.
SOURCE: I'm not getting heat from my unit..
the compressor is controled seperately from the fan, this is done with the thermostat, try turning the thermostat on then of or untill you hear the "click" sound from the thermostat. If the compressor is still not turning on this may be more than you can fix if your not familiar with electrical hvac troubleshoting... more than lilkely the thermostat may be bad, or your compressors starting components are failing...if the compressor is comming on when the unit is turned on you could have a freon leak causing no heat. hope this may help some there is just too much to write on the causes this will give you a start though!!
