How do I hook up to the tv- red and white?
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
The Buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music . Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Bule...
You also can use bluetooth headphone:
Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo...
The ends of your headphones are RCA. Some tvs don't have RCA plugins anymore The red is right sound and the white is left sound. If you can't find a spot then plug it into the cable or satellite receiver box.
USE a VCR between the PS2 and the Sylvania TV. Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4. Set the VCR channel to Line 1 or Line 2. This should work. I hope it helps you.
