My hp 8250 is leaking black ink from the bottom of the printer. How do I fix it?
Actually your printer needs servicing but for temprory solution.take a bunch of tissue paper .keep the printer on and the printer cover open so the cartridge will be in the center.then with the tissue paper place it internally on the side from where its leaking.the sponge which collects the wastage ink is at present got full and now it does not have the capacity to soak the ink.so its leaking.as you will place the tissue papers the ink will be soaked by tissue paper and the sponge will again become bit dry to soak more ink.but its the temprory solution.to make it permanent get the printer serviced and sponge replaced.the problem is not all serious ,its common.every printer comes to this stage after certain usage.and the servicing is the solution.a local printer repair shop also does the servicing job .
hope this helps.
thanks.
