Multiple beeps while starting up is most of the time a message for a defect in the hardware. Try taking out some parts, put 1 by 1 back in and after placing 1 part, try to start up first. Thats an easy way to find the part thats defect. Most of the time its a dying ram. If you want to test the ram first, you can use the program Memtest 86+
if its a single long beep....then ram is misplaced or damaged....
SOURCE: WHAT IS THE CAUSE OF 9 SHORT BEEPS IN DELL
Usually a system beeping is what's known as a post code- and can indicate a severe hardware problem. The likelyhood is you need to contact 1-800-456-3355 (dell technical support) since the research I've pulled up for a 3-3-3 beep code is "Motherboard has failed"
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: what is the problem if
If it were a desktop computer, with a removable video-card, then re-seat the video-card.
But, since it's a netbook, the video-card is not removable.
So, about the only removable part is the RAM. Remove the RAM, and re-seat the RAM.
If all else fails, take it to a qualified technician for professional repair.
