BOSCH Nexxt 800 Series washer keeps saying Suds or pump blocked and will not complete or drain water out to go onto next cycle.
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: Bosch Nexxt 800 series. We have continued problems
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1
min then plug it back in it should drain by its self if not do not select
wash cycle but a spin/drain then you should hear the pump running, if you
don't hear the pump running you can get a wet/dry vac stick on the
drain hose and empty the washer, that way if water does not come out you have
to access the pump and pinch off the drain hose from the tub and remove
the object from the pump, be careful that you don't have a mess with
water leaking from the tub good luck.
Thanks
SOURCE: Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining. Replacing the pump on a Bosch machine, please check this link for tips:
