LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code OE
My LD-12AW2 LG dishwasher is coming up with error code OE, will start ok (no leaking or anything) then gets throught to about 5 mins of operation then stops with error code OE, then if I press start again it will start back up from where it stopped but will then go back to the error code after a few minutes, will now not do a full cycle. Help!!
  • Anonymous May 04, 2009
    we have the same problem. No idea whats wrong with it.
    Hence why I am googling to see that the problem could be. We already had an issue with the motor last year costing us $300.
    We regret this purchase.
  • Mike Scarchilli
    Mike Scarchilli May 04, 2015
    yes i have the same issue with my LG LDF6810ST we also replaced the entire motor assembly last year so i knew it could not be the drain motor... I checked it has 27 ohms and when 120 volts applied it works.. no drain blockage as i opened every hose and took the screen off to check everything. Drains fine on gravity once you take the drain loop down to ground level. So i guess the last thing is the control board relay which must not be sending power to the drain pump when required... Repair clinic has a 365 day no questons return policy so i will give it a try
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on May 06, 2009
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
903219
Points
9207
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
4helpful
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Error code OE
The error is DE - DRAIN ERROR , Not fully drained out in spite of 5 min. drain operation
Possible causes
¥ The Filter clogged.
¥ The Drain Hose kinked or blocked.
¥ The Drain Pump/Motor or circuit is troubled.
Possible solutions
¥ Clean the Filter.
¥ Remove the cause of kink or block.
¥ Replace the Drain Pump/Motor or repair the Circuit.
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
DISPLAYING OE ERROR CODE
What did the original poster with the OE error find?
An OE error = Dishwasher not fully drained out in spite of 5 min. drainoperation
Remove the cause of kink or block in the drain hose.
Remove the filter and confirm that there is no debris in the sump area, especially the drain pump outlet.
Check the wiring connections, especially in the wiring harness in the door panel. Look for "melting" insulation.
Measure the electric resistance of Drain Motor. (good=20-40 ohms) Replace the Drain Motor if out of spec.
Good Luck!
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
1helpful
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
1helpful
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
3helpful
2answers
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 • Dishwashers
4helpful
2answers
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
