Gh5184xps3 microwave
this cause noise ; God bless you
MagnetronIf your microwave is
emanating high pitched or growling noises during operation, the
magnetron could be going bad. Normally a nearly silent part, the
magnetron uses high voltage and induces the frequency required to cook
food. Although normally not a safety hazard to operate, this is a sign
that the magnetron is failing and will need to be replaced as soon as
possible.
Exhaust fan motorIf
your microwave is making a very loud humming noise during operation, it
could possibly be the exhaust fan motor. If defective the part will need
to be replaced to silence the appliance once more.
Stirrer motorAnother
leading cause of a noisy microwave is an expired stirrer motor. With use
this part becomes worn and makes a loud grinding noise, which is
usually a leading indicator that the part needs to be replaced. The
stirrer is a metal blade that is slowly turned by the motor. This action
disperses the microwave energy in a random pattern, which heats the
food evenly. If the stirrer motor is determined to be nearing
expiration, it should be replaced to halt the grinding noise.
Turntable motorA very
common cause for a noisy microwave is a worn out turntable motor. This
is a relatively easy repair and will put an end to the noise once
replace
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
