the lock/unlock button on the Cuisinart Smart Stick CSB-75 blender may not stay locked when pressed in. The solution is to hold the blender in the palm of your dominant hand, press the low or high button and hold, then push and release the lock button on top with a finger on your other hand. The blender motor should start as soon as you push the lock button down and stay running until you release the high or low button.
However, fix.com offers OEM Black and Decker blender parts and accessories, including rubber gaskets, jar bases, measuring cup lid inserts, and blade assemblies. You may want to check if the parts you need are available and replaceable.
If you are unable to repair the blender yourself, you can contact Black and Decker customer service for assistance. They may be able to provide you with additional information on how to repair your blender or direct you to a local repair shop.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
IF YOU ARE ALREADY STUCK: Find the tiny detention/release "button" in the grove at the back near the top of the base unit. Use a butter knife or the back of a sharp one to slide the button DOWN toward the counter (not in toward the blender blades).
TO PREVENT THE PROBLEM: Look at the 4 locking tabs on the single serve cup. They are rectangular with the lower right corner HEAVILY beveled (when viewed broadside). The solution to the problem is to LIGHTLY bevel the upper left corner too. I used a pocket knife to shave just a little bit off at 45 degrees. Proceed carefully one tab at a time testing it in the rear slot. Shave just enough to get an easy release. Shave all 4 tabs on the cup so it doesn't matter which one is inserted in the rear groove.
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
