Is this a gas washer? Is was connected up when I rented my apt. but only scalding hot water comes out. If I turn down the only water I see going into the machine, it just lowers the pressure until I shut it completely off. Help! How do I get to the cold water?
SOURCE: Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings? If on warm setting and water flow is cold, its probably the mixing valve. This part isnt that expensive, and not that hard to replace. Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top. You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit. You will see the mixing valve right where the inlet hoses connect to the machine. Let me know if you need further help.
SOURCE: Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
SOURCE: Cold water doesn't work in my washer
There's no cold water
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
if this helps please vote me a fix ya
SOURCE: Kenmore 90 series washer no hot water
CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
SOURCE: cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
