Toshiba Satellite P30 (notebook) I removed the keyboard, monitor, hard drive, and top cover to repair a dirty/sticky power switch (would not power up) While disassembling, I unplugged 2 wires I believe are power supply to the monitor 1 black and 1 white. These 2 wires plug into a module designated as a 2.4DSOF4 (problem is I looked away briefly and lost concetration) these wires plug into 2 jacks labeled "main" and "aux" I need to know which one goes where. (black to where? and white to where?) Also I should replace the power supply swich since I opened the thing up to fix that in the first place. Who supplies these micro switches? (5 terminal switch)
Unsoldered the master power switch and the reverse scan button (micro switchs) from the mother board and traded each others place, (the reverse scan switch into with the master power switchposition and vice versa.) Allowed the two confused wires to hang naturally and took a chance and plugged them in where they seemed to remember being plugged in. re-assembled and working good.
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Hope this helps.
Remove laptop battery.
Remove two screws securing the hard drive cover. Remove the cover.
Remove one screw securing the memory cover. Remove the cover
STEP 2
Pull the hard drive to the left. Disconnect it from the motherboard and remove.
Remove both memory modules.
STEP 4
Remove all screws from the bottom of the laptop.
STEP 5
Remove the keyboard bezel using a smal flathead screwdriver.
Be careful, it's fragile.
STEP 6
Remove four screws securing the keyboard.
Press on the plastic lock (red arrow) and release the keyboard.
STEP 7
Lift up the keyboard.
Be careful, it's still attached to the motherboard.
