SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
SOURCE: My gas power washer will not start. I filled the
Will it run if you pour a small amount of gas in the carb? If so, it's a fuel supply problem. Most likely a stuck closed float needle.
SOURCE: 93 mustang lx turns over
I suggest you check for spark by taking a spark plug wire off one of the spark plugs and using one of your old plugs and crank it over and see, it wouldn't be the first time a module died on a Ford. Plus if you have a fuel pressure tester hook it up and check for proper pressure if no gauge just shoot a couple of squirts of engine start or carb spray in the intake if it starts something wrong with your fuel system recheck wiring conections if you don't hear fuel pump, turn on key from 3 to 5 seconds fuel pump should run to prime fuel rail then stop, if not check fuel system.
SOURCE: I have a 15 year
Hello ghb. Continue with the starter fluid. It sometimes takes 2 or 3 minutes to clear the carbeurator. IF after that, it still won't take off then you will have to rebuild the carbeurator. Joe
Thanks for choosing Fixya!
SOURCE: gv 250 wont stay running
Engine stalls easily. 1. Fouled spark plug. 2. Clogged fuel hose. 3. Clogged jets in carburetor. 4. Valve clearance out of adjustment. Clean. Clean. Clean.
Adjust.
