Yellow light and Fan not work on my pride battery charger model: HP8204B
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
SOURCE: batteries not charging - just replaced
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
SOURCE: Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
SOURCE: The battery charger does not work. The red light
SEEK AN ELECTRICIAN WITH HIS METER WHEN SOMETHING GOES WRONG WE TEND TO THINK OF THE WORSE THINGS RATHER THAN THE BASICS,IM DISABLED MYSELF,THE BATTERIES ARE TO BE TREATED WITH RESPECT,I DONT KNOW WHAT CHARGER YOU ARE USING BUT PLEASE ONLY USE WHAT IS ADVISED BY MANUFACTURER,NOT ONLY THAT IF YOU DONT YOUR WARRANTY WILL NOT BE VALID.HAVE A NICE DAY COLIN.
