I bought a sandisk sanza m250 mp3 player and i plug it n2 my imac and it pulss a screen up in my the find file saying audible config and record then sys_cond.dnc now i cant install the disc because its one of those small kind which wont fit in a mac so i think i threw away my money but hey prove me wrong
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
This is hard to explain but you do have files on your player.. It is like having 2 players in one, or 2 different memories, check out this tip posted here...Solve your MP3 Player Connection Problem.
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Spoken Word Browse the Audible audio book file in alphabetical order. Press the Play/Pause/Up Button or Repeat/AB/Down Button to browse through the audible audio files. Press the Select Button to browse the songs for the selected file.
This player has an MSD/C vs and MTP option - in one mode, you will only see the audible, config, etc- in the other mode, you will be able to see the music files, but not record - very annoying
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files: Audible 1) Adding audible books to your MP3 player using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv 2) Adding books from an online library to your computer using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv 3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv 4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv 5) Deleting a book from your library using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv 6) Purchasing an audible book from Audible.com (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
This may or may not help you, but I've connected my Sansa m250 to two computers. One has Windows XP and the other has Windows 2000. And neither can see the other's files. The file structure you describe sounds like what I see on the Windows 2000. For some reason it shows it as a disk - the same as a memory stick. It can't see what was drag and dropped or loaded by Windows Media Player. So I would make sure I used the same computer that was to used to transfer the files.
