Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hi
Error code FH appears when No water is detected
entering machine or Pressure switch trip is not detected. If after 30 seconds
the control does not detect water entering machine and then valves will be
turned off and the error code will be displayed. Press PAUSE/CANCEL twice to
clear the display. If there is no water entering the unit then make sure that
the inlet valves are working fine. You may need to check the continuity at the
inlet valves. If the valves are fine then check whether inlet water hoses as
they might be plugged. Also check for inlet water screen at the valve. However,
if the water is entering into the washer then the Drain pump might not be
working. Also inspect the Pressure Switch hose whether it is in good condition
and properly connected to Tub and Pressure switch. Also check hoses for leak
and inspect the flow meter. Hope this helps...
Daniel
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
This happened to me, but pushing the Pause/Stop/Cancel button does nothing. It does not display "PF" after starting up...it still flashes the time remaining (which can change to any program, but still flashes a "time" regardless of the cycle setting)
