I have a Whirlpool (model GHW915090W) front load washer. After the rinse cycle completes, the water drains out ok. After a while the water starts to come back and fill in the steel drum, slowly but surely..Can anyone give me some hints on what might be the issue, and how to solve it.. Thanks in advance..
Use the attached video to show you how to access the inside of the machine.Ignore the other parts other than access and re-assemly.
Thanks for the responce. I took off the drain hose, and ran water through it to make sure there was no blockage. In order to make sure the pump is clear, how do I go about getting into the washer to get to the pump? I have the user manual, but it doesn't state the best way to take it apart...
Thank you so much for the video. I will watch and attempt to take apart to check hose and pump...I'll be sure to let you know if it works..
Thanks again..You guys are great..
I turned off both water values as stated in one of the solutions above and the water didn't appear to fill back up in the drum. I as I turned the cold water on still no dripping, but when I turned on the hot water values it started to fill back up. So it does appear that I have a defective water value which I will replace. Hopefully that is the only issue. I will also check the drain and return hose to ensure they are not clogged. Thanks for the heads up to all who posted a comment...
You may have a defective water valve. Next time you run the washer, when it completes the cycle you are talking about, turn off the water faucets and see if the water returns. If not replace the water valve.
