Question about Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
I think the problem is in the valve, not the shower head, since back massagers also are leaking. I read that it is probably some ring or valve behind the handle that both turns water on and directs water to one of the three water delivery mechanisms. Gray plastic plug looking thing in center of handle, I suspect hiding the screw to remove handle to get to leaky ring. I am afraid to destroy the plastic handle plug for fear my theory is not right, and then husband will scold me for doing that! Tired of waiting for him to fix it (been 6 months!), and I think I can do this. :) Any advice?
  • 1 more comment
  • Patti Abbott
    Patti Abbott Nov 05, 2013
    The model info showing above is not right. I don't know model, we just bought the house, bathroom remodeled around 2002-2005?
  • Patti Abbott
    Trying to attach pictures
  • Joseph Michael Oct 20, 2019
    Hi Patti. Can you share how you got the grey plug out. I am having the same issue. Thanks.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Maax is the shower surround. The valve has internal parts that are bad and that will be another name.
Posted on Nov 06, 2019
    New Friend:
  • 41 Answers
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Posted on Nov 05, 2013
6ya staff
SOURCE:
Anonymous
  • 61 Answers
SOURCE: leaking maax shower drain
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Posted on Nov 12, 2008
36069
  • 35 Answers
SOURCE: hi we just bought a maax breeze neo corner shower
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Posted on Nov 19, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: How do I install maax corner shower doors?
Here it is...
Be patient it is a large pdf file...
http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
heatman101
Posted on Apr 23, 2010
J-Chris Ward
Chris Ward
  • 731 Answers
SOURCE: We purchased a home with the Maax Hydromax
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=27963&ven=3726866
This is the only site i could find they might be able to get the info for you
Posted on Feb 05, 2011
Richard Crate
  • 157 Answers
SOURCE: Trying to install a Maxx
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Posted on Mar 26, 2011
Hot water pressure very low in maax shower any suggestions to correct?
Assuming that the flow control is not defective, your water heater may be limed shut.
Heating water (especially 'hard' water) causes calcium to precipitate out and build up in the bottom of the tank which can cause poor recovery and if heavy enough, reduced flow.
Check yours and you should find a drain located near the bottom of it.
Attaching a garden hose to this and opening the provided valve will allow you to flush out the loose lime.
You should turn off the AC or gas supply before doing this to stop the heater from trying to reheat while you are emptying it.
Good luck-
Aug 22, 2014 | Maax 105124-L Imagine Shower Enclosures
Loss of water presure
Depends upon the brands of the shower fixture
Apr 06, 2014 | Maax RainForest - Three-Piece Corner...
Maax iris b leak in corner of fixed panel
Sometimes you have to override inadequate instructions with application of some common sense. It might be interesting to know why Maxx thinks the inside track should not be sealed. Also, test for water migration from where it should be to where it shouldn't be
Jul 13, 2013 | Home
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Dec 16, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Leaking maax shower drain, can I remove the grate and seal it from the inside?
try this:
Nov 09, 2008 | Maax Shower Drain 10000041-105
Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1 Logo
2,557 people viewed this question
Top Maax Plumbing Experts
Jay Saari
Jay Saari
Level 1 Expert
john h
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
