SOURCE: ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
SOURCE: Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
SOURCE: GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
SOURCE: yahoo.commy u-line icemaker is leaking
Hi pachingoman,
If you're experiencing water leaks into the ice tray, it is often caused by the water inlet valve. This is sometimes called a weeping solenoid. The easiest way to correct this is to check if the valve is seal properly or dirt has come between the seal of the valve. If the seal itself is bad, please replace the water inlet solenoid valve. Here are additional troubleshooting that you may apply on this issue.
1. Check to see how big your ice cubes are.
2. If your ice cubes are very large, then then is sounds like your valve isn't sealing off and the water valve will need to be replaced.
3. If the cubes are smaller, then it sounds like the icemaker is leaking water out into the bucket causing the cubes to be small and the bucket ends up a big block.
4. If it doesn't happen all the time, sometimes frost will build up under the icemaker and all you need to do is just thaw the unit out for 24 hours and the problem will fix itself.
It is common for the ice maker to leak overtime. However, if the ice cubes are smaller you definitely need a new ice maker I'm afraid.
Hope it helps.
Thank you for using FixYa.
